Changing A Fluids Properties Over Time (particle Samplerinfo)
Hi there, Im experimenting with some fluids and i have a question.
As with particles and PerParticle attributes, with the partisampler you can wack a ramp on an attr and drive that to effect something over time.
Is it possible to do this with a fluid. Does a fluid have a lifespan?
For example, When a fluid is emitted i want threshold to be 0 and as it gets older i want it to be 0.3
Or at emission, the fluids amplitude is 0.4 and as it gets older it becomes 1.
Or at emission the ratio is 0.5 and as it gets older its 1.
I know how to achieve this if im fluid shading particles but is this achievable with fluids alone?
Thanks in advance.
QUOTE(RaGzMaN @ 01/26/06, 05:15 AM) [snapback]226206[/snapback]
As with particles and PerParticle attributes, with the partisampler you can wack a ramp on an attr and drive that to effect something over time. Is it possible to do this with a fluid.
You can animate some settings over time, and you can add ramps to the texture and shading attrs. But you can’t with any of the fluid dynamic settings. The fluid calculation settings hapen before it will read the ramp so it will only take the ramps out value, that won’t change. The value doesn’t change because…
it does not. So if you were to add a ramp there is nothing to way when to end so there is nothing to say how fast it should move from one point to another on the ramp.
Yes you can by animating the attributes, or if you waqnt to consider distance older you could project a ramp on the side of the fluid so that as the fluid travels to the other end of the container that’s (shader or texture) attribute changes.
Hi there thanks for your reply.
Can you please explain about your method of putting a ramp on the side of the fluid, im not sure i follow as this sounds like something im after.
Unfortunatly, when altering the ratio or threshhold for example over time by simply keying it, the fluid thats emitted holds these attributes obviously. What if i wanted a fluid to emit with one setting but as it got older, or effectly further away, it took the characteristics of an altered attribute if that makes sence. An example might be from a liquid to a solid.
thanks again.
