Mar 2004
1 / 3
Mar 2004
Mar 2004
Hi.
I need to change the diffuse color of the material when export as dotXSI.
But I can't change the material color with a file texture on it.
In Softimage3D I can change the diffuse color even if file textures are assigned to.
In Maya, I can do it by changing the default color attribute in the file texture property panel.
How can I do this in XSI?
  • created
    Mar '04
  • last reply
    Mar '04
  • 2
    replies
  • 2.1k
    views
  • 1
    user
The only way to do that is by disconnecting the texture from the illumination shader. Otherwise the texture output is taken as the diffuse color. I don't know the specifics about dotXSI files though, maybe it is editable if the file is in ascii format.
Cheers
Bernard
That's sad..
OK maybe I need to use softMaterial.
Thank you for your reply.
