First make a back up copy before preceding.
locate the folder in this dir
Program Files\Pixologic\ZBrush3\ZData\ZPlugs\SplashData
you will see a text file called Startup.txt
the dir/ directory will be like this depending on what drive your have it installed
mine shows C:\Program Files\Pixologic\ZBrush3\ZData\ZPlugs\SplashData\Startup.txt
in the Startup.txt edit the top line by placing this
[IColorSet,148,148,148]
[ISet,Document:Back,148.58038]
[IColorSet,254,254,254]
when you start up zbrush 3 your background color will change.
so you want to chose your own color instead of one i posted?
first start zbrush and pic a color
then press Document>Back
now end the record and open up that text file in a note pad
look at the bottom of the text file and you will see some thing like this
this will change your background color
BUT you will need a third code to set the color back to allmost white
so ill place this at the bottom
ok now you have the 2 codes from the text file and then add the third to the bottom
so it ill look like this.
in the Startup.txt edit the top line by placing the code above.
