Can somebody tell me the tool for colour boolean using the material id / object pass-multi color pass, i have a mattepass with various colors applied for each props and parts of props also. one way of using is key each color and create the matte, is there anyway we can use channel boolean, and assign these HUE as material id and SATURATION as object id and play with color correction.
You can do it if you setup your material id colors correctly. You can use the rgb channels of the colors and combinations of them to set different material IDs. Then you can take the material id color in nuke and process it thru some simple boolean arithmetic tools and you'll get black and white matte of the given material. This is one way to do it:
CODE Mat# red green blue booleans equation 01 0 0 0 (inv red) min (inv blue) min (inv green) 02 0 0 255 (inv red) min (inv blue) min green 03 0 255 0 (inv red) min blue min (inv green) 04 0 255 255 (inv red) min blue min green 05 255 0 0 red min (inv blue) min (inv green) 06 255 0 255 red min (inv blue) min green 07 255 255 0 red min blue min (inv green) 08 255 255 255 red min blue min green
So for example you need to set up a material id for material number 07. You setup its color to RGB (255, 255, 0) and render it. Then to get a matte our of it you invert the GREEN channel and do a MIN operation between the result of the invert and the RED and the BLUE channel and you'll get white only in the areas where your material id was set as RGB (255, 255, 0). Hope it makes sense.
