Hello everyone. I want to animate a simple scene with a character holding an item in its hand. What would be the best way to handle this? would it be to to parent the item to the hand controller or animate it with the hand?
Also the character will be resting its h and on a table top, is there any way with constraints to keep the hand from intersecting the plane?
yes you’d want to parent constrain the object to the hand and you’d want to parentconstrain the hand to a locator on the table so that when the rest of the body moves it does not force the hand to rotate into the table.
Use parent constraints if you need the character to pick up and drop the object. There are ways to avoid penetrating a plane, like a floor for example, if you use FBIK. Are you?
