My script is failing to make connections to nodes that have been defined as part of a Maya character.
First I'm I'm checking if the destination Atrribute is locked, no problem there -
I'm also checking if anything is feeding into that attribute by iffing this
(connectionInfo -isDestination ($dstAttr)==0)
This was working ok , 'till I tried it on a node that was part of a character : Maya makes its connections for the character, but this gets seen as a connection by the above check.
So, how can I check to see if an attribute has an incoming connection, unaffected by any charater setups?
Cheeeers!
