Check emitter/particle connection
Bearing in mind there may be multiple emitter/particle combinations - How can I tell if a given emitter is connected to a given particleShape? is there a direct way, or do i have to scan the arrays of one or the other end.
cheers....
Window -> Relationship Editors -> Dynamic Relationships...
Select your particle object from the list on the left.
Click the "Emitters" radio button along the top
You will see a list of all the emitters in your scene, and the ones that emit your particle object will be selected. you can select or deselect emitters here to change which emitters emit your particles.
-r
Robin
robin@uberware.net
yeah cheers, but given that I'm posting under this category, I didn't specify that I was seeking a MEL solution..
thanks anyway
You can get this by doing a listConnections on the "newParticles" flag..
listConnecitons particleShape1.newParticles
see if that help.
-jason
jason schleifer
animator
weta digital
nice one. thanks.
