Cloth AND batch render issues
if you are having problems with your cloth not simulating in your batch render, but it was working fine in the viewport and playblast. make sure that your start frame in render globals is the same as the start frame on the cpSolver. if these two values are diffirent it seems to screw up the simulation. this worked for me. good luck.
