Thanks for your reply gmask, but I've already tried this solution without success. Maybe if I give you an example, you'll understand my problem better.
Create a sphere and a cube, parent the cube to the sphere.
Select the group node an create a cluster ( relative on). Now, parent the cluster to the group node.
At this point, if you check the cube's pivot point, you'll see that it's not moving anymore so if for example you animate a transformation on the cluster, you can't animate the cube anymore because of its pivot point.
With this easy example, you should be able to understand the exact nature of the issue.
Do you see a way to keep the cube's pivot point centered and moving and still being influenced by the cluster.
I appreciate your help
Tank you
