Can you import DV captured as Video for Windows into Combustion?If so, do you require a special codec?And, where would you download itfrom?
Sorry,I want to import DV/IEEE 1394 Capture and import that into Combustion.Does Combustion handle this?
Thank You
as far as I know, combustion doesn't support DV at all, maybe in combustion2what I did is convert the dv footage into uncompressed tga files which combustion supports and then ouput them into the desired formatwala walahope this helped
Question: why uncompressed tga? Targa uses RLE compression, which is lossless, and supported by anything that reads tga. Smaller files, no quality loss...
______________________Brian DemongPublisher, Combustion InstructorMesmer Animation Labs
yeah i made a mistake when i wrote uncompressed tga i was thinking about the RLE compressor actuallyyou're right it's lossless and good, so...
Thanks all...
Yes I ended up converting to tga.thanks again
Error: Backend Fetch Failure
