Collecting Multiple Bounding Box Entries
Hey,
A few weeks back I got some help about running commands on entry to bounding box's..
Here was the final code I had from here...
int $objectIsInside;// on/off switch
int $time = currentTime -query;// get current frame
vector $cylBBox[] = xform -q -ws -boundingBox pCylinder1;// cylinder's BBox
vector $cubeBBox[] = xform -q -ws -boundingBox pCube1;// cube's BBox
if ( ($cylBBox[0] < $cubeBBox[0]) && ($cylBBox[2] > $cubeBBox[2]) ||//check X BBox
($cylBBox[3] < $cubeBBox[3]) && ($cylBBox[5] > $cubeBBox[5]) ||//check Y BBox
($cylBBox[3] < $cubeBBox[3]) && ($cylBBox[4] > $cubeBBox[4]) ||//check Z BBox
($cylBBox[2] < $cubeBBox[2]) && ($cylBBox[0] > $cubeBBox[0]) ||//check -X BBox
($cylBBox[4] < $cubeBBox[4]) && ($cylBBox[3] > $cubeBBox[3]) ) //check -Z BBox
if (!$objectIsInside){//if not true set to yes
$objectIsInside = yes;//check if object is in BBox
} else {
if ($objectIsInside) //if true set to no
print ($time);//print current frame
$objectIsInside = no;//check if object is in BBox
What I would like to be able to do to add to this, is to be able to select a group of objects, like the cylinder thats used in the above code, and select a second group of objects, like cubes from the above code, and have the time recorded each time one of the cylinders enters or exits the bounding box of the cubes.
I am getting really confused about the way in which to do this, any help would be very much appreciated.
Thanks, Chris
Check out the link to the video.
Is this sort of what you're trying to achieve? I've only got it working with one volume field at a time, I hope to get it working with nurbs objects later on
Voxel Field
Cheers
Brent
