Collision Problem (2)
Hi evryone, I have one of those bizare thing in maya...
I have a file with 2 cloths. The first time I run the simulation, everything work fine, but if I run the simulation one more time, the cloth pass through the collision object, untill i open the file, and then the same, first simulation fine, segond and next don't collide.
the normal are fine, i've tried cm and inch. the model is 1m68, so normal proportion, i've checke nearly everything, and yesterday evening i did a few simulation that work great (there were only one cloth yesterday)...somone have suggestion...
are You running local simulation? If Yes, then run first frames of normal simulation, and then rewind to 0, delete cache, and simulate locally again.
