Color Space Management
I'm a bit confused with this color space management thing in photoshop..or perhaps just in general.
While in photoshops color settings, do i chose my monitors color profile or is that where i want to chose something high quality like adobe rgb, and then for whatever document i work on i give it a color space based on its final output?
ok, here's the way i understand it.
The colour spaces allow you to move your images from one medium to another and get predictable results.
Unfortunately scanners and printers can display far less colour than a monitor, the CMS allows you to predictably translate what you see on screen to paper. If your images are going to stay on screen, say for web or TV you can stay in the sRGB profile.
If your image is going to a printer you can set it up with that printers profile and then the colour you see on screen will be limited to those you can print. You can preview this effect on sRGB or other profiles by clicking Ctrl Y. If your printer uses the Epson DP987 printer or something like that you give your image that profile.
Digital cameras will often attach a colour profile to he image to compensate for the ccd or cmos and lighting, you should use them, and convert the profile to sRGB or whicever you decide to work in.
Your monitor profiles are really for display purposes, if you have two monitors by differrent manufacturers it just makes sure that they will display the same colours... well most times anyway. If you move images between a mac and a PC you'll notice a perceptable jump in brightness, if you've turned colour managemet off.
You select your monitors profile in the display settings of your OS.
take a look through the PS help, they go into some depth on the subject.
Okay this is realy confusing but the profile you set in photoshop has nothing to do with your monitor profile its jut the arbitrary workspace you choose to work in. It could be your monitors profile offcourse
The sytem settings sets the icc for your monitor (in widows its in the advanced under view preferences). Photoshop then converts whatever space to your monitorspace for viewing (but if you have not set anything in this menu photoshop asumes srgb wih isnt accurate but nice guess). It emulates any device you can even preview waht it will look on printted right there as well as its technicaly possible on your monitor.
Anyway like above said the conversion is problematic.
read: http://www.boscarol.com/pages/cms\_eng/ it prettymuch explains teh whys and hows of profile to profuile conversion
Anyway no generic profile mathces YOUR specific monitor, it need sto be measuured reguulary witth a iccing isntrument otherwise its not accurate. Even the manuifacturers profiles dont realy tell the truuth there sw considerable variation form monitor to monitor.
