Color: visible banding
Hello.
I’ve got a problem when rendering a large empty grid (phong shaded f.e.), with a point light above..
You can clearly see the color banding. The unsmooth transition towards the falloff. The manual suggests
using the dithering option.. Well, that doesn’t seem to work.. I thought why not render to 16 bit color depth?
That doesn’t work either.. What am I doing wrong?
Thanks in advance,
Sander.
okay, this may seem like a really silly bit of advise…but…is your colour depth on your video card set to 32 bit.
im also slightly confused about why you rendered to 16 bit colour depth, it seems that you think this would improve the banding, but surely it would actually cause it…hence the above advise.
hope this helps, silly as it may seem :slight_smile:
We’re running XSI at a color depth of.. er, true color. So how many bits that is…, I guess 24? Anyway, I’m running under NT 4.0 on a 320, so true color is the highest I can get.. I’ve tried viewing my rendered image on another system, but the color banding stays visible..
Put the image online, and see if others see the same thing.
24/32-bit is fine for viewing images. The exact 8-bits is just for a transperancy channel.
I’ve had colour banding effects from low antialias settings when I render in BMRT. Try pumping them up a bit to see if they go away.
Also, on the web to jpeg’s appear smooth for you?
-Vijay
If you’re getting banding, it means your samipling thresholds aren’t low enough. Open your Preview/Render options and go to the “aliasing” tab. Reduce the RGB sliders to 0.05 for each color and try rendering again. You should see much of the banding disappear albeit at a slight penalty in speed. You shouldn’t lower these values to anything less than you need.
If any banding still remains, then increase your anti-aliasing and/or add one of the filters such as a gaussian and increase the sampling size from 1x1 to say 3x3.
Matt
Matt Lind
Animator / Technical Director
Softimage|3D
Softimage|XSI
speye_21@hotmail.com
