Curious as to whether ColorPlus by ColorPantoneVision is a good purchase for calibrating my 20" Dell LCD?
Or is hardware really necessary for proper calibration?
Thanks,
Thanks,
Well, heres the thing. the hardware does in generaly not calibrate your monitor… calibration would mean something entirely different, which pretty much would mean the nentire monitor should be redone. FOr monitors theres some possibility of doing calibration at factory laboratories but in general its never done.
WHat instead is done is something people sometimes wrongly CALL calibration and that is to determine what amount of wrongness the instrument shows. For monitors its not rely about right or wrong but rather what is. THis creates something called a ICC profile, and I am afraid theres NO amount of manual scrying that can doe this perfectly.
If you work for print and you want out the colors you choose use a image profiler tool… but note not all screens are so well suited for icc profiling. Now ofcourse if you intend to use icc profiles you must understand that your background lightning affects what you se. As des your printer which too need to be profiled. FOr tv work this is often not neccesery, because theres no substitution of a broadcast monitor. For film i’m not sure but iccs should be able to account for this.
