Is there a way to combine 2 character clips together and then activate them to get the curves back?
My goal is to remove all clips from a character and just have unbaked original curves remaining.
Many thanks
If they dont blend then i don't see why not.
I can use combine with no problems - but once I activate that combined clip it bakes a keyframe onto every frame. Is there a way to avoid that?
Not really since thats the only plausible way to do it in general. But you can assemble the curves yourself. As long as they dont overlap its easy whan thay do overlap then your only option aside form getting better at calculus than i ever was is to sample by steps. Its not impossibly hard to do merge of 2 curves but if theres a envelope than it allmost absolutely is.
