Combine Keys In Shake
So I've read tons about people saying to pull a good key you need to combine different key methods because they all work the best in specific situations. So I learned couple of methods and now would love to know how to combine multiple keys into one seamless result? Any tips or idea behind this method or sample script somebody is willing to share would be awesome. I'm new to the forum and friend of manuals so try not to be too harsh
Thanks in advance.
Michal
An simple add will do the job...
I think you are safer with an over, screen,or keymix to combine mattes. Especially
if you are dealing with delicate edges and blurs.
Keymix also works well if you want to combine mattes with a soft split, which is often the case. I like to have different comps with their alphas without splitting them up with rotoshapes yet, targeting specific areas, then keymix them together with the rotoshape at that point. That way you have less of a chance of having holes where your mattes meet and I feel like it gives me more control to change
things while seeing the final result. And you will have a final matte at the end of
it all.
Catherine
QUOTE(catherinet @ 12/03/05, 03:36 PM)
it all.
Catherine
[snapback]221467[/snapback]
did some reading in the manual as well. its little more clear now, but still takessome time to wrap my head around it. Also whats a good way to clean up shadows on a blue or greenscreen?? Also whats a good way to preserve them?? Whats you favorite method??
Thanks
QUOTE(mimik2005 @ 12/05/05, 09:31 PM)
Thanks
[snapback]221626[/snapback]
Primatte can do magic things.I use a hard contrast key with an inside node
(or in invert > Garbage matte input of Primatte) in some parts (softer in air regions, different borders etc...)
I think everyone has their own methods, and you are lucky if you can have one method that always works (actually, you are living in a world that we all dream about). The best thing is to get some footage and play with it.
For me I rarely go past Keylight for my fine keys but will usually use primatte for holdout mattes. And the keychew macro in the cookbook is one of the most useful tools EVER!
Do a search on keying in the forum and listserver archives, there are some fantastic bits of advice and technique. I keep a document full of great tidbits from here.
Cheers,
Toby
I think the trick is being armed with many keying and suppression techniques, as there is often a vast range of footage problems that need to be treated differently. Keylight might be the answer for one area of the footage, or a luma key on a particular channel might be the solution for something else. Primatte may work for another scenario. All of these tools may be used on just one shot. Different suppression techniques, like Keylight, HueCurves and Spill suppress may be used to process the foreground. Maybe a keylight matte will be used with a HueCurves foreground for example. Whatever works and looks good!
Catherine
