Hey- I forgot to add the following - - -
After you Update your Edit..Remember to Update the Edit Browser TOO!
At the beginning of May, Discreet announced that an improved Version of Edit Browser for Discreet Edit Version 6.0 is available as a FREE DOWNLOAD. Called Edit Browser V 2.5.1, this 5MB program provides a number of Edit Browser enhancements including: Improvements to combustion integration, Multiple selection drag-and-drop operations, Improvements to source timecode transfers between jobs, and Wheel mouse navigation support for the Preview window.
To Download the New Version, go to :
http://www.discreet.com/support/edit/downl...php3#edit%206.0
Please Note that to Install this new version, you MUST UN-INSTALL the old version FIRST- - - The correct steps to perform the UN-INSTALL are:
1) Insert your edit 6.0 CD-ROM and browse to the editBrowser folder
2) Run Setup.exe and follow the steps indicated by the installer
3) When prompted to Modify or Remove, select "Remove"
4) Once the installer has finished you MUST reboot
After your computer has rebooted, you will now be able to install the New Version of edit browser v 2.5.1. Here are the steps:
1) Download the File from the Discreet website (listed above)
2) Unzip the downloaded file (reqires WinZip - not included)
3) Run Setup.exe from the folder where you chose to unzip the file to and follow the steps indicated by the installer
4) Re-Boot the computer.
regards,
Jack, Denmark
