hi, as you can see, i have a very simple question: is there a mel command that ends the whole script (like break does to a loop) ?
Thanks,
Z
Thanks,
Z
no, you can only use "return" to exit a procedure on a defined line. Usually you will wrap your script in a proc so this should be no problem.
proc test() {
do stuff
if (abort)
return;
do other stuff
// auto-invoke test procedure.
test();
thanks for the reply!
i actually wanted to break the whole process. i can use the error command but i wouldn;t like ERROR to be the written as outcome : )
use catch
