I created this mech in a short time because i have to finish a project of mine. There is still something that bothers me about him - he looks uncomplete. I think i should add more detail?? And what about the texture It still doesn’t look real. Any suggestions ??
Like what kind of details should be added and so forth..
Thanks in advance..
Floepi
It looks wimpy…i could beat that thing up! i dont know exactly what your going for but mechs should have more fire power. here are some of my suggestions (only my opinions, so you dont have to do any of them at all. its just waht i think wich may not be worth myuch to ya’):
- atach some sort of rocket pack to his back
- maybe a gun on the head?
- rounds wraping around his torso
- more GUNS!
- it yuo could make his legs bigger that would be cool
Well what I would do is make the texture look dirty with peeling paint. The paint part I would make a different color. Something darker so he looks more menacing. Also make it less bumpy. As for detail add Breathing hoses, wires, air vents comig off of the mech. Maybe a back pack or something that has weapon attachments. For the black parts I would change the shader. If you want I can send you one that looks more like Rubber with a nice bump on it that makes it look textured and cracked. I would also add more components to the leg such as visible motors and attachments. The grey parts need to have a better metal shader. You can get one here at Highend3d or I can send you one also. Maybe add something around the pelvis such as belt and attachments like extra magazine. Hope this helps out and let me know in a reply if you need any shaders. I got them off of Highend most of them but made the Rubber one.
Thanks,
Theaps
Hi, not a bad image you posted there…
I just think it looks as if it has a VERY resricted range of movement, maybe you should put in some hydraulic cylindars and pipes, and some flashing lights to make it more futuristic. Also it doesnt seem to have a very sturdy chassis, try basing your next mech on a sturdy chassis, like a car. If your mech rolls over, you want it’s vital ‘organs’ to be safe. Also put in some useless details like bolts etc. Details (modelled) go a long way to making a good image into a great image. Good luck wth it.
-Gav
(technical Illustrator)
I like it. Why should everyone’s robot have the same look? If the only bots that were considered appropriate were the “totally buff” and “rad” power bots then we’d probably never had seen R2D2 or C3PO. Try working a bit on the textures (age the textures, etc.) as mentioned earlier and then pose the robot. Positioning the model in a dynamic pose can add a lot to your model’s personality and visual impact.
Thank you guys for your nice suggestions. I will work on it a little and post it again. So you will see that i take your comments seriously.
But it won’t be any more guns
Thanks
Floepi
