your free to do whatever looks good.
QUOTE(frd @ 05/22/06, 04:26 AM) [snapback]237832[/snapback]
You can generally apply an Ambient Occlusion pass to a scene using the imult node.
Yes and no. Depends on how you construct your scene. uiin general terms no.
if you start with the diffuiuse color and them mult with occlusion fine! And then add all additional light on top of that.
Hioever note occlusion is just something that describes how the abient light is distruibuting better than one constant color. So in general the occluison should be added to your object. Offcourse itll need to be tinted the way each surface acts on it but.
QUOTE
You can generally apply a Global Illumination pass to a scene using the _____ node.
Again read the one befre it depens on how you order your network. Theres no general rule to how you do a effect juts how things relate to achother and general ideas.
