Compositing/rendering For Demo Reel:
Hi people!
I got some serious problems and have no experience with this type of stuff so would be great if U help me.
I'm in the process of demo reel creation. I rendered all animations from my 3d app to frames as .tga sequences. All animations speed are: 24fps, resolution is: 1024x576.
What I want is to put my frames into After Effects to do some simple compositing stuff and prepare it for dvd.
I know I must render all my animations out from After Effects as a lossless avi or mpeg2 stream and load that into DVD authoring tool. I really have no experience with it.
I made some test. So I created new project, then put .tga sequence, then created new composition - here I didn't knew what type of resolution to choose coz I have 1024x576, then I render this composition as --> make movie, looseless avi and then also quicktime. But in both examples I get lower quality then in the source .tga. But in After Effect 'Comp' window sequence looks exactly as a .tga sequence, strange.
What next, I wanna prepare my reel for both systems: NTSC and PAL. My source frames are 24fps so I now that for NTSC animation will be little faster, that's no problem. I don't know what settigns should I use for NTSC and PAL, U know all this issues with TVs resolutions. The resolution of my animations is: 1024x576, should I in example scale it by 70%??? I need this stuff to be perfectly well fit into TV on both systems, I don't wanna my animations be stretched from one side or another becouse of wrong settings/format or something like that. Black bars from up and down are acceptable in this case, right??
So here again the list of my problems:
1.how render out all these stuff to look the same as source targas(the same great quality)?
2.how to preserve 1024x576 'cinematic style' format on both ntsc and pal?
3.how set After Effect for render stuff out to ntsc and pal? There r many presets and pixel aspect ratios in AE.
4.what about dvd bandwitch settings?
5.what authoring tool do U suggest? Premiere?
Please help
Answers to questions I know
#1 When you render out of after effects you can be getting compression unless you select uncompressed quicktime. When you go to DVD however You will not be getting the same quality as .tga sequence. Just how it is man. It's the compression for DVD.
#2 You got this one right from what I understand. I'd just scale it to 70% in a new comp set for NTSC or PAL
#3 NTSC D1 DV Preset and PAL NTSC D1 DV Don't choose square pixels unless your coming outta photoshop is generally a good idea.
#5 Sonic Reel DVD is great and my recommendation
One more thing there is a setting you can render with if you're using pc in after effects for dvd it's called MPEG- DVD
If you use sonic you'll need this setting
Hey jtate, many thanks for answer. Now I can start to work.
