85 sounds a little hot to me,...that is Degrees C yeah ?
you could fry an egg on that (I've a bookmark somewhere to a site documenting the process if you're interested
I only ever get up to 60 with a real heavy session,...but have a lot of fans on the machine as I'm a little paranoid.
To rule out the Ampage cause though, check the mobo's spec in the documentation, or on the Manuf's web site & compare this to the info on the little sticker that's on your PS (usually on the side you see when your case is opened) which should by rights display Voltage, Wattage & Ampage info.
