Connect A Duplicated Shape Node To A Skincluster (2)
Dear all, I want to connect “inMesh” attribute of a duplicated shape node to a skinCluster node. This shapenode is duplciated from a cylinder in bind pose, and then I rotate the joint to change the bound cylinder leaving the duplicated one untouched. If I perform connection (connecting skinCluster.outputGeometry[1] to duplicated.inMesh ) directly, then the duplicated cylinder just turns to the current pose as I expect. HOWEVER, if I save the scene and reopen it, the connection doesn’t work!
Following is what I did, a very simple test:
  1. create a cylinder mesh (pCylinderShape1)
  2. create several joints, and then “Smooth Bind” to that cylinder
  3. duplicate this cylinder (pCylinderShape2)
  4. rotate a joint to some degree. (the duplicated mesh is left in the rest pose)
  5. then execute:
    Connected skinCluster1.outputGeometry to pCylinderShape2.inMesh
    using Connection Editor
  6. result: the duplicated shape pCylinderShape2 turns to the pose of the original one.
if I save and reopen ( just adding a step)
  5. save and reopen
  6. then execute:
    7.result: nothing happens for the duplicated shape (pCylinderShape2 ).
thanks to any suggestion!
I don’t know, what’s happening to your scene, but I’ve tried the same manipulations like indicated and everything works fine. Even when I save and reopen the scene before connecting the skin Cluster with the duplicated cylinder.
But why connecting the skinCluster with the duplicated cylinder and not a simple connection (inMesh/outMesh). But well…
Perhaps you can save your scene and send it, so I can take a look at it.
Carlo
