Connect skeletons to another?
I want to create a Mel script to connect and disconnect the orientation, rotation, and translation of two identical or similar skeletons, thus allowing for rapid attachment and detachment of a control skeleton to a deformation skeleton.
I have no background in scripting, but this functionality is important enough to me, that I'm already diving into every book I can find on MEL scripting to try and make it happen.
While I'm working on this, I want to put out a general query, see if this script already exists, or something similar is out there already.
Let me know, I'm curious, and interested in any feedback.
Ok... I think I've got enough MEL knowledge to be able to attempt this.
How would I go about moving up and down a skeleton hierarchy though?
You will want to get the hierarchy into an array and then loop over it.
Some thig like...
string $h1[]=listRelatives -ad -type joint -f "RootJoint";
for($i=0; $i < size($h1); $i++)
// do stuff
--g
Thanks a ton g for the help. That part is definitely usefull. But I apparently have less of a firm handle on MEL then I originally thought.
chews on fist
How do I get MEL to interface with what I select, and then shift select?
I've got something REAL basic, but it's still too much for me,
string $controlSkeleton[] = ls -sl -hd 1;
string $deformSkeleton[] = ls -sl -tl 1;
connectAttr -f $controlSkeleton.rotate $deformSkeleton.rotate;
// Error: Invalid object or value: joint6 //
I need a little nudge guys... Basic kicked my ass all through highschool, so my head hurts real bad right now.
Thanks
With Mel you can't just push together variables and attributes like you have. You'll have to do it in a eval() statement something like this..
evalEcho("connectAttr -f "+$controlSkeleton+".rotate "+$deformSkeleton+".rotate");
evalEcho is the same as eval just it will echo the command it run to the script window.
Hope that helps you along.
Dave Biggs
Is a case where you dont need eval, this works also an is easier in many ways.
connectAttr -f ($controlSkeleton+".rotate") ($deformSkeleton+".rotate");
Also you could concatenete teh strings piror into an array containing the entire list of switches and pass tharray simply on to the command it also works!
I wish I could say success. I ripped apart the MEL documenation... Learning a lot for sure, but I can't figure this one out. Anyone else?
// Error: connectAttr -f ($controlSkeleton+".rotate") ($deformSkeleton+".rotate"); //
// Error: Illegal operation "+" on data of type string[]. //
something that might help you is this script:
zooSortToHeirarchy
basically, just give it an array of objects, and it sorts them into a heirarchy order. something like this:
string $sourceRoot = "source_root"; //root of source skeleton
string $targetRoot = "target_root"; //root of target
string $srcHeirarchy[] = zooSortToHeirarchy( listRelatives -ad -type joint $sourceRoot );
string $tgtHeirarchy[] = zooSortToHeirarchy( listRelatives -ad -type joint $targetRoot );
for( $n=0; $n
anyway, i haven't tried that, but something like that should be good...
