Connecting attributes in shading network
I have a pretty standard setup, using a supressed maya blinn shader with dgs material and dgs photon shaders appropriately attached to it. i thought that i would simplify the shader tweaking process by having the maya shader drive the mr shaders. i connected the color attribute of the maya blinn to the diffuse attr of the dgs shaders, and i also used the specular color of the blinn to drive the specularity of the dgs shaders. everything worked as expected, but it generated these errors:
// Warning: (Mayatomr.Nodes) : Blinn1.specularColor, current plug value used instead: unsupported type of connection //
// Warning: (Mayatomr.Nodes) : Blinn1.color, current plug value used instead: unsupported type of connection //
the problem is that when there are many shaders setup this way, cycling through the error messages during the translation stage of the render can really slow things down a lot. first of all, why is this connection not supported and what effect does it have on the image generated, bc i am not noticing any? secondly, how do i fix the problem?
i also tried something else in this setup that did not work. i tried to use the connection editor to set the attributes of dgs_material to drive dgs_material_photon since so many of the attribute shared between these need to be set the same and i was wasting a lot of time going back and forth between the two to tweak values.
this time it does not render at all. i get this error in my log:
API 0.0 error 301041: incorrect member "transp", "dgs_material" does not return a struct
what does this mean and how do i fix it?
thanks in advance,
chad
