Hi! Is there any tools or methods to constraint an object to a particle?
Thanks!
Thanks!
This is an example expression to get you started :
Make your object and rename it object1. Turn on vertex snap and create a particle where your object is. Then apply this expression
// Get position of particle 1 in particleShape1
$particlePos = getParticleAttr -array true -attribute worldPosition;
"particleShape1.pt[0:1]"
// Fix object to particle
setAttr "object1.translateX" $particlePos[0];
setAttr "object1.translateY" $particlePos[1];
setAttr "object1.translateZ" $particlePos[2];
Now apply a dynamic field to the particle (make sure its linked in the relationship editor) and play it back. The object should be fixed to the particle.
