QUOTE(animotion3d @ 07/27/07, 02:05 PM) [snapback]270505[/snapback]
are you joojaa from sourceforge.net?
Yes.
QUOTE
so in your opinion we should use connections with utilities instead of expressions for calculations , right ?
No thats not what im saying, just no MEL/PYTHON inside EXPRESSION language.
Well see heres the thing, expressions arent equal to mel but expressions eat mel quite happily. Theres a sort of people that THINK they are equal but theres a big difference. And that is if i type:
objectA.translateY=10; //this is expression syntax
it effectively equals to me writing the following mel
setAttr objectA.translateY 10; //this is mel syntax!
However theres a BIG difference. objectA.translateY=10; gets compiled into a node as a input connection to the expression node. setAttr objectA.translateY 10; will just be saved as a literal string to be executed. Now it so happens that maya nodes don't not know the names of stuff in the scene. So if you were to reference the later it would still point to objectA.translateY whareas the first would reference to whatever it is connected to!
But thats only the paek of it the later is also 10 times slower and also prone to way much more error for a number of reasons. Most prominently ist a dg nde thats acting against the dgs design. SO if it feels like hitting your head against the wall its because you in fact are doing just that.
theres no way of solving use of mel in the nodes im afraid, without always preprocessing all expressions after reference. But for obvious reasons this is stupid. Mel is just not designed to be called form expression nodes, just because you can does not mean you should. (maya 8.5 supports api load filters you can solve it with that easily, but dont theres a reason it works like this)
After all it is possible to go but trough the balcony even if its at 10 floor, but for some strange reason people prefer elevators. Its the same kind of subtle difference. Maya does not care how much easier it is to shift the furniture out the window, instead of trough the door and elevator/stairs because ultimately in the end cleaning up your mess is more work for maya.
