Control points and isopharms
How can I set a NURB surface to have control points on isopharms, not between. I have seen a model having control points exactly where isopharms intersect.
Thanks, Dragos
they are called edit points (EPs)
go into component mode, and on your top tool bar, turn off the square and turn on the circle. you should see little Xs, those are them.
