Convert instance into real obejcts
i have bunch of objects instanced, with modified scale and translate. I now wish to convert all those instance object with new shape Nodes, is there a way to do this?
select instances
make plain copies ( duplicate with copy option )
delete original instances
that only work for one object not multiple. ie you can't duplicate all instance, it results in other instances for dome reason...
No, it works perfectly for multiple instances. Did you try it?
yeah i did, with other options too, but it doesn't work. maybe because I did instance on another instance, but I dont think there is such a thing.
Eventually I had to duplicated it one by one, freez transform,..which what I needed originally, which instance couldn't freeze transforms
Try deleting construction history before duplicating
