I am using a fluid (hard surface) to create a displaced ground effect (plane hitting ground)and wish to texture it, so have converted my fluids to polygons. Is there a way to get the poly mesh to displace/animate with the fluid displacement?
if you have history enabled when you convert to polys then it will have animated displacement
