hello!!
I want know how copy a file .tif used in maya on texure or reflection map??
for exporting that to a new repertories for used this in motor 3d????
Thank you
hello!!
Thank you
QUOTE(xabi @ 04/11/06, 09:05 PM) [snapback]233988[/snapback]
hello!!
Thank you
Hi
Do you want copy a file from one location to other location ???
then u can use SYSTEM comamnd or
string $destWindows = "C:/temp/mayaStuff/myimage.tif";
string $srcWindows = "C:/maya/projects/default/scenes/myimage.tif";
sysFile -copy $destWindows $srcWindows;
or you want anything more ???
regds
o.S.k
use system command. you can do usual commandline opperations with it.
system("copy c:\temp1*.* c:\temp2");
and make use of file -q -ex $fileName; to check availability...
Than you i go test that
