Is it possible to copy weighting from one object to another?
I have a polyobject, which has been converted to polygons from Nurbs. Both objects are therefore 100% the same - except from the fact that one is of polys and the other of Nurbs.
I have enveloped the polyobject and now I would like to copy the weighting to the Nurbsobject. Is that possible?
I never tried this approach from a polygonal object to a nurbs one, but I assure you it works for poly to poly:
Set the envelope on the target object. You need an envelop operator.
Make sure that the target objects has the same deformers as the source object.
Tag all the points of the target.
On XSI Net there is a script (well, an xsiaddon) that allows you to copy weights. The addon is located in Net View > XSI Net > Tools > General > Property Maps/Weight Maps > Envelope Copy.
Run the srcipt, pick the source object.
It should work, it did for me a couple of times.
Hope this helps
Salutations - Cheers
Bernard Lebel
