Creating a dg node and using it?
As I understand it dg nodes are displayed in the hypergraph (dependency mode). I want to create one of the nodes listed in the dag node reference, via mel.
createNode "copyUVset" -n "test" -p "subdivSphere2Shape";
creates a node but it seems to be blank ... ?
addAttr doesn't seem to be what I'm after.
can I only instantiate these nodes via the api?
cheers
ktpr
"S" in "copyUVSet" needs to be a capital letter.
You have to look at the attribute list either with a listAttr command, or in the connection editor, as none of the attributes show up in the channel box or attribute editor.
Also, you won't be able to parent this node, as it only exists in the DG not the DAG.
-hope this helps
-james
thanks that helps a lot. I can now connect nodes up and see their effects and learn from them. btw what is the difference between DG and DAG. I assumed that DG was a weird abbreviation of Directed Acyclic graph
cheers
ktpr
When I typed "DG", I was refering to the "Dependancy Graph".
The hypergraph view mode that displays
the data flow of the selected items in your scene.
-cheers
-james
DAG refeers to how the parent child mechanism iterates the positions by post multiplying matrices. And because it needs to be predictable it cannot be cyclic. Since then the whole perfrmance of ita ll would be thrown out of the door and it would become a simulation (wich offcourse can be done but as allways it carrues some problems inherit with it).
in dg you are however allowed to do as many loops as you wish its only your ability to predict the outcome that sets the limits!
