Creating an outdoor environment?
I am having a little trouble setting up and outdoor environment. I guess it’s because of my lack of understanding of the scale features between Maya’s paint fx and the actual outdoor scene. I am sure after I play with it awhile I’ll get it figured out, but I would like to ask you guys/gals how you go about setting up an outdoor scene.
Do you create a closed environment, like a hillside surrounded by trees that doesn’t go all the way to the horizon? Do you use a dome light configuration? If you’re just going to use a small part of a forest, do you usually fake the outside lying forest features, or do you model it?
I understand that most of modeling comes down to the best tricks you can think of to pull off an effect, but I just wanted a little bit of insight into how others go about creating an outdoors environment.
Thanks in advance for any input.
Chad
Thanks for bringing up this point again I posted a questions a page or two ago and no one responded… oh well? I’ve done environments a couple different ways. I did a paint fx enviroment using the dome light approach which actually worked out fairly decent. I used a sphere for the sky and a nurbs plane for the ground which I sculpted to get that rolling hills effect. This worked since I rendered from a few different points of view. I’ve also done the “model only what you need to show in the shot and nothing more” which worked but doesn’t give really that feeling of submersion and can be a problem if you move your camera at all. If your trying to get the scale right you should just try the dome light and nurbs ground and scale it resonably large then just paint a paintfx tree on the nurbs plane and then go in and scale the tree to fit the landscape, then you can save the brush and keep using it. Hope that helps.. let me know if come across anything that really worked well. If anyone else has opinions please feel free to express them. How do the pros do it? How do you give that feeling of a grand scale and a truly submersive environment?.. thx!
You wouldn’t happen to know where I can get a good Dome light setup? Or on how to build one?
I’m sorry when I say dome light I may be thinking of something totally different. I created mine by creating a huge nurb plane and the sculpting it, then creating a sphere for the sky so the ground completely intersects it on all sides to prevent any visible seams.
Check out the GI Joe setup at Emmanuel Campin’s site, pixho.com.
Mr. Campin generously provides our community with worthwhile and highly valuable tools.
You can controll the size of paint fx brushes by scaling your brush down, b+mmb drag to adjust the size. Depending on what you want to use the environment for you can go about it differently.
If you plan on moving through it then you will need to model more of the landscape to allow for camera movement. Just remeber that the more stuff there is the longer it will take to render.
If you are going to have a central area of focus, where action is taking place, model only the area that your characters will interact with (sort of like a stage for a play) then you can use a seperate BG plate and composite it into the shot later. Read up on render layers.
Try to think of it in terms of your scene and what shots are going to take place there, this is where storyboards come in handy, if you don’t see it you don’t need it. Try not to think of 3D as the real world, it isn’t and thats the beauty of it, you can fake everything and as long as it doesn’t show up in the shot no one will know. think of it as a movie set and you are the director with the ability to do things you can’t do in real life.
Aslo using a realwordl panoramic image isnt that bad either! Especialy for reflections
