QUOTE(persius @ 09/27/07, 10:41 PM) [snapback]273978[/snapback]
I'm a little uncertain as to why SubD's would be used when Polys are the norm from my understanding?
Theres nothing norm about polys over subdiv. Blend shapes work exactly the same over both of them
QUOTE
To put it simply, what type of mesh should I be working with when using polys? that is, a low density, or high?
quite simply where you want the blend to happen in history. Theres plenty of reasons to put it at both places can't know ahead of time since i dont kneo your history chain or intent.
Only way to know is to undertand how things work. Even then its a question fo what your after.
There are no rules to do things in the world, the only thing that lats you decide each optimum is to understand how you do things.
