QUOTE(yvonne206 @ 07/09/08, 06:25 AM) [snapback]288105[/snapback]
Thank you for your advice! But I am not experienced enough yet to be able to do what you tell me, sorry. Where can I get that DVD 14?
unfortunately this dvd isnt available anymore. but this (nr.13) would be helpful, too:
http://thegnomonworkshop.com/dvds/dyn13.html
nevertheless, if you dont need the depth of field effect it's quite simple:
create a plane, chose emit from object, set random speed, select particle object and use the sprite wizard and chose a snow image with alpha you created before.
if you don't know how to follow these steps, then you shouldnt use a highend tool like maya to achieve this effect
(except of course you're about to really learn it, but then you could start with easier things or read the manual on dynamics first)
