Creepy Bathroom
Hi everyone, im new! This was a shading and lighting project for a Full Sail class. I did the modelling, lighting and shading.
The following is a render of the final scene, and a few wireframe shots (I tried smoothing the wireframe in one of them, but the faucet part comes out looking crappy). From what I can tell on my own, i need to put more bump into the rust on the pipes.
Any feedback and/or criticism is more than welcome! Thanks!
This is the render at full resolution:
Creepy Bathroom SL Final BIG render
What type of surface modelling did you use to create the tub. It looks like PolyProxy Smooth but I just wanted to ask. Great Work!
it looks like nurbs atleast from the screengrabs, could you invest some time in getting the lightning better. Aslo include a icc profile on the image so that it displays with proper gamma for those of us (or asume srgb space) with not same gamma as you. As of now it a tad too dark (even if the image would be dardk no world realy reacts like a 1 pont lightning sceme, in dark scanes the amient boinces become more prominent makeing MORE lightning in order than less)
The modelling is pretty well rounded except that your wall looks like two polys perpendicular to each other (which is no doubt exactly what it is). It just stands out, that’s all
Modelling isn’t lacking, but your dynamic range is, the image looks very bland. You could either review your lighting (you need more range, highlights etc), or throw it into shake/combustion and pull the levels, add some glows.
I like the blood on the mirror
hey! i like your work a lot, though i agree with the rest of the ppl about the lighting, needs a little more work on that, other than that… good job!
NIce lookin renders. I don’t mind the lighting, the lack of light adds to the mood. I agree with the wall comments maybe join those two objects together and make the corner a bit rounder.
Apart from that its a great lookin shot
Good work
Jason
Actualy im not against the darkness of the picture per se. BUt rather the fact that the icc wasnt embedded. because on this computer it looks nice. Because the picture in fact IS quite bright with the right gamma.
It’s about the range as somebody mentioned already. Even pictures that represent utterly dark environments must have small portions that are extremely bright. That way there is something to compare the darkness to therefore the darknes becomes much more expressive.
Otherwise, the image looks simply underexposed ( which is the case with this image, icc or not )
