Dear all,
I am quite new in this website and I have a problem with cubicVR that I installed in MAX 9 with vray 1.50.
I did some cubic views and it worked well but now there is something that goes wrong with a new model and new scene that I have created. The normal render works ok but the problem I got with cubicVR is that it starts to render well infact each of the 6 frames are identical to the normal render views, but as soon as it finish to render one scene suddently it make it all black and then it pass to the next one. So this means that for each of the 6 views I see the nice render till the end, but then when the scene is all rendered (as usual) BEFORE passing to the next one cubicVR make the current scene just black. So I end up with 6 black frames... The thing I dont understand is that how come the normal view renders ok and also cubicVR renders ok till the end but then WHY does it make it black?
Many thanks if you can help me to understand where is the problem.
Keep in touch and have a good day.
Stefano
p.s. moreover is it possible somehow to use the plug-in for the ambient occlusion for a video render instead rendering just a single still image?
