I want to constrain an object to a specific .u POINT on a curve so that when I move the curve or it's CVs around in the viewport the constrained object(s) stay locked to the same position along the curve (rather like beads on a rosary)
This is how the Measure > Parameter Tool seems to work, when you stick a parameter locator on the curve it stays at EXACTLY the same .u position on the curve when you manipulate it.
however, if I try and do it with objects (using geometry constraint) they stick to their curve but they don't stick to the correct .U position so as I move the curve around they bunch up and end up all at one end. (which isn't undoable either..?!?)
am I using the wrong constraints?
how do I lock an object to a specific .u position of a curve..?
use A pointOnCurveInfo. or use path anim without animating the u parameter!
edity:
oh and then theres the least squares modifer... that you can get form teh deformer menus point on curve thing! wich is the reverse of the above strategies
hmm.. thanks.. I fiddled around with the pointOnCurveInfo node and I've got the objects locked to the curve fine.. but now they're locked I can't manually move them along the curve!
I really need to be able to move the objects up and down the curve they're constrained to (manually using the move tool), but when I move the CURVE, the objects stay in the right place along the curve as it moves..
I guess I can have only one or the other... I'll have to make the user click a button to lock/unlock the objects.. oh well.. I suppose I could use a script job which locks the objects if a curve is selected, or unlocks them if an object is selected.. seems a bit excessive though...
