Problem is essentially as described in the subject. I'd like to be able to write a tool that can be run from inside the graph editor or a model panel, but my initial tests are only registering doPress events from within model panels. Anyone have any ideas how / if this can be done?
More elaboration: This is for an interactive time-scrubbing tool that needs to be able to jump around the timeline as the playhead hits certain frames (the start and end frames of shots) and would be hooked up to some hotkey. So the tool kind of needs to work in any place that a user would ordinarily be able to scrub time ( which in practice, around here at least, is really just panels and the graph editor). So if anyone has any ideas for alternative approaches Im all ears as well ! (I initially implemented this with a mel draggerCtx, but really want to get in to that graph editor, hence looking at API options)
Thanks!
