This still doesn't work (compute function does nothing), but is this close to what you meant:
import math,sys
import maya.OpenMaya as OM
import maya.OpenMayaMPx as MPx
import maya.OpenMayaAnim as Anim
nodeName = "circusDPNode"
nodeId = OM.MTypeId(0x00032331)
class circusDPNode(MPx.MPxNode):
aInTargetMatrices = OM.MObject()
aTargetSelector = OM.MObject()
aInConstraintMatrix = OM.MObject()
aOutOffsetTranslate = OM.MObject()
aOutOffsetTranslateX = OM.MObject()
aOutOffsetTranslateY = OM.MObject()
aOutOffsetTranslateZ = OM.MObject()
aOutOffsetRotate = OM.MObject()
aOutOffsetRotateX = OM.MObject()
aOutOffsetRotateY = OM.MObject()
aOutOffsetRotateZ = OM.MObject()
def compute(self,plug,data):
if (plug == self.aOutOffsetTranslate or plug == self.aOutOffsetRotate):
selector = data.inputValue(self.aTargetSelector)
parentIndex = selector.asInt()
thisNode = self.thisMObject()
plugArray = OM.MPlug(self.aInTargetMatrices)
outRotArray = OM.MPlug(self.aOutOffsetRotate)
outTransArray = OM.MPlug(self.aOutOffsetTranslate)
numInPlugs = plugArray.numElements()
numOutRot = outRotArray.numElements()
numOutTrans = outTransArray.numElements()
if parentIndex > -1:
if numINPlugs in range(parentIndex):
parent = data.inputArrayValue(self.aInTargetMatrices)
parent = data.jumpToElement(parentIndex)
parentMatrixValue = parent.inputValue()
parentMatrix = parentMatrixValue.asMatrix()
constraint = data.inputValue(self.aInConstraintMatrix)
constraintMatrix = constraint.asMatrix()
mOutMatrix = OM.MTransformationMatrix(parentMatrix.inverse() * constraintMatrix)
vOutPos = OM.MVector(mOutMatrix.getTranslation(OM.MSpace.kTransform))
vOutRot = OM.MEulerRotation(mOutMatrix.eulerRotation())
vTargetAxis *= parentMatrix
vConstraintAxiz *= constraintMatrix
vToTarget = OM.MVector(
parentMatrix(3,0) - constraintMatrix(3,0),
parentMatrix(3,1) - constraintMatrix(3,1),
parentMatrix(3,2) - constraintMatrix(3,2))
outputHandle = data.outputArrayValue(self.aOutOffsetTranslate)
outputHandle.jumpToElement(parentIndex)
outputHandle.set3Double(vOutPos.x,vOutPos.y,vOutPos.z)
outputHandle = data.outputArrayValue(self.aOutOffsetRotate)
outputHande.jumpToElement(parentIndex)
outputHandle.set3Double(math.degrees(vOutRot.x),math.degrees(vOutRot.y),math.degrees(vOutRot.z))
data.setClean(self.aOutOffsetRotate)
data.setClean(self.aOutOffsetTranslate)
else:
OM.MGloabl.displayWarning("Not enough targets or outputs")
else:
return OM.MStatus()
else:
return OM.kUnknownParameter
return OM.MStatus.kSuccess
@classmethod
def createNode(cls):
return MPx.asMPxPtr(cls())
@classmethod
def initializeNode(cls):
mAttr = OM.MFnMatrixAttribute()
nAttr = OM.MFnNumericAttribute()
pAttr = OM.MFnMatrixAttribute()
oAttr = OM.MFnNumericAttribute()
uAttr = OM.MFnUnitAttribute()
cls.aInConstraintMatrix = mAttr.create("inConstraintMatrix","icm")
mAttr.setAffectsWorldSpace(True)
cls.aInTargetMatrices = pAttr.create("inTargetMatrix","itm")
pAttr.setArray(True)
pAttr.setUsesArrayDataBuilder(True)
pAttr.setAffectsWorldSpace(True)
cls.aTargetSelector = nAttr.create("parentSelector","ps",OM.MFnNumericData.kInt,0)
nAttr.setMin(-1)
nAttr.setDefault(-1)
cls.aOutOffsetTranslateX = oAttr.create("outOffsetTranslateX","ootx",OM.MFnNumericData.kDouble,0.0)
cls.aOutOffsetTranslateY = oAttr.create("outOffsetTranslateY","ooty",OM.MFnNumericData.kDouble,0.0)
cls.aOutOffsetTranslateZ = oAttr.create("outOffsetTranslateZ","ootz",OM.MFnNumericData.kDouble,0.0)
cls.aOutOffsetTranslate = oAttr.create("outOffsetTranslate","oot",cls.aOutOffsetTranslateX,cls.aOutOffsetTranslateY,cls.aOutOffsetTranslateZ)
oAttr.setArray(True)
oAttr.setUsesArrayDataBuilder(True)
cls.aOutOffsetRotateX = uAttr.create("outOffsetRotateX","oorx",OM.MFnUnitAttribute.kAngle,0.0)
cls.aOutOffsetRotateY = uAttr.create("outOffsetRotateY","oory",OM.MFnUnitAttribute.kAngle,0.0)
cls.aOutOffsetRotateZ = uAttr.create("outOffsetRotateZ","oorz",OM.MFnUnitAttribute.kAngle,0.0)
cls.aOutOffsetRotate = oAttr.create("outOffsetRotate","oor",cls.aOutOffsetRotateX,cls.aOutOffsetRotateY,cls.aOutOffsetRotateZ)
cls.addAttribute(cls.aInConstraintMatrix)
cls.addAttribute(cls.aInTargetMatrices)
cls.addAttribute(cls.aTargetSelector)
cls.addAttribute(cls.aOutOffsetTranslate)
cls.addAttribute(cls.aOutOffsetRotate)
cls.attributeAffects(cls.aTargetSelector,cls.aOutOffsetTranslate)
cls.attributeAffects(cls.aTargetSelector,cls.aOutOffsetRotate)
def initializePlugin(mobject):
mplugin = MPx.MFnPlugin(mobject)
try:
mplugin.registerNode(nodeName,nodeId,circusDPNode.createNode,circusDPNode.initializeNode)
except:
sys.stderr.write("registerNode failed")
raise
def uninitializePlugin(mobject):
try:
mplugin.deregisterNode(nodeId)
except:
sys.stderr.write("deregisterNode failed")
raise
