Is it possible to cut and paste a selection of UVs from one set to another?
Sounds like a basic question : )
There is a tool "Polygon > Transfer" that will do this. Though it only works between geometrically similar models(vertex order is the same).
Use the following command to copy UV's from one set into another.
polyUVSet -copy -uvSet "source UV set " -nuv "target UV Set"
Hope this helps.TomB
Assuming that you want to copy between UV sets on the same object that is!
TomB
thank you for the answers!
But this won't let you take just a portion of the UVs. i.e. supposing you want to copy the UVs of specific polygons (not the whole set). This will override the entire target UV set.
The new version of Bonus Game Tools on the A|W site has a tool called Copy UVs Between UV Sets.
I haven't had a chance to try it yet, however. If you give it a shot, let us know how it worked.
--JeffD
