This is probably an easy fix, but does anyone know how to cut and paste between a terminal window and the maya script editor within kde...
I have installed the fam rpm which is supposed to allow this to work... anyone else run into this problem?
-justin
justin@cyburdine.com
this was solved by AW support and thought someone might benifit.
Issue: My mouse isn't working in the 3 button configuration, I couldn't cut and paste from window to window.
From a terminal window type mouseconfig and choose the mouse type and configuration from the following screens.
Try using the X clipboard; highlight the text you want by dragging the left mouse button to highlight it, go to another text field window and middle-click. Voila. (Caveat: The start of the copied text is placed directly under your cursor in some circumstances.)
Or is this problem less general than I think it is...? I'm probably out of the loop here. |P
