QUOTE(totoro9 @ 06/01/09, 07:34 AM) [snapback]308696[/snapback]
How do i cut curves
Switch to Curve Point selection mode, click where u want to cut, Do a Edit Curves > Detach Curve.
Split a curve or surface (detach)
Unless you mean the Cut Curve function, which cuts where 2 curves intersect.
Edit Curves > Cut Curve
and merge point in the curves
Edit Curves > Attach Curves
Join curves or surfaces together
should i merge point on the curves when i birail them ?
Surfaces > Birail
Sweep one or more profile curves along two path curves (birail)
Gotta love the manual ![]()
