D-day Omaha beach test render
www.juansnm.8m.comomaha.html
I modeled this scene with 3D Studio Max 4.2 and textured it with Corel 10. I rendered it with brazil r/s 1.00.
I was inspired by the film “Saving Private Ryan”.
I ask all of you to “shoot at will” with comments about anything in this test render and to use your best criteria to do it.
Thanks.
Juan
PD: if someone can tell me why cant I render transparent objects ( such as the barbed wire ) with Fog activated I would really apretiate it.
Look more like an ingame shot from either ‘Medal of Honor’, or ‘Battlefield 1942’.
Not bad at all. Doesn’t look braziled, which is good. Nice…
Fog-Wire—DOn’t know.
The first thing that catches my eye is the sharp edge where one of the fortifications meets the embankment. That area needs some texture detail at very least, or maybe more geometry too.
It would also be nice if the steel barricades connected to the ground better. Their current shadows don’t look quite right. If you look at your sky, it’s a very overcast day. Not a time for hard shadows. Preferably you would have soft shadows with a dark emphasis right near the point of connection.
Finallly, everything could be dirtied up some more. You could probably use more irregularities on the concrete; water damage, impact marks and pocks from cannon hits (if the assault is already underway), whatever. At very least, plant some sawgrass to hide those connecting edges. Think about painting in some erosion damage to the embankment, perhaps with some small plants clinging on. And finally the beach itself could use some more debris; just ordinary flotsam; bits of bark, different-toned lines of seashell bits and gunk that tend to form as the ocean recedes… that sort of thing.
Your horizon line reads pretty well, along the crest of the hill with the bunkers. The sky’s ok too. The foreground and midground are the areas for work.
yes it definitely looks like a screenshot from one of the popular first person shooter WW2 games that are out now.
Pay closer attention to real world textures in life for the objects around you. If you look close enough you will soon realize that it is almost infinite. You don’t have to shoot for infinity (and beyond!!! sorry couldn’t resist) but try to approximate it just enough to fool the eye. That will be your toughest challenge.
Also your lighting looks very bland. Take more time making adjustments and rendering out tests.
Hi There,
Nice start, here’s what I see…
The lighting is off, it’s cloudy, yet everything is bright, but then there’s dark shadow areas as if it were completely dark.
The clouds in the sky do not look full and thick, there seems to be no texture to them. That may just be the flat lighting, but I would suggest doing some texture work there.
You need bump maps, and diffuse maps…on everything.
You used the same texture for both bunkers…that’s a no-no.
I am still impressed, either way, it looks very in-gamish, which if that’s what you’re going for then great! If you’re going for a realistic look, then you’ve got quite a ways with texturing/lighting to go.
Best regards,
Joe
Hi everybody,
Yes, the textures and the lighting aren
