Dark areas on poly surfaces
Hi Everyone,
I’m not sure what exactly is happening here, but I’m having trouble with some areas of some poly meshes having darker areas. Similar to when you have overlapping across poly edges, but in this case the geometry is clean.
Any ideas?
Thanks,
skyPhyr.
Normally this is because you have inverted polygons. Try to select them, right-click/Alt right-click and choose Invert Polygons. This should do the trick.
A good way to see if your polygons are correctly oriented is to turn on the Normals in the Eye icon of the viewport. Inverted polygons will show blue lines facing the other side.
Hope this helps
Salutations - Cheers
Bernard Lebel
Hi Bernard,
The polys are all facing the correct direction - probably should have mentioned that before.
When I say dark they’re not completely black they will just get darker towards an edge or point, not the complete black of inverted polies…
Thanks,
skyPhyr.
It’s possible that you have clusters with a different material. Have you assigned local materials?
Also, is your surface continuous? I mean, you might have applied a Geo Approx and put 0 in the discontinuity angle, resulting in faceted polygons…
Could you post a picture? This would help to understand, because I really don’t see what the problem is…
Bernard Lebel
is this when you render, or just openGL?
if it is when you render, have you any textures/bumps on your object?
post a pic…
a
Hi Guys,
It’s there both in opengl and render. Top is OpenGL bottom is render region.
It looks as though it’s lighting in the rendered one, but the lighting is perfectly even across that surface.
I’ve tried drawing in more edges, but doesn’t matter how I do them nothing seems to fix it. Even deleting the faces and redrawing in new polies doesn’t help.
Thanks for the assistance.
Cheers,
skyPhyr.
SkyPhyr,
Thanks for posting the images. But there is one missing: The wireframe view!
It appears that when in openGL mode the shading changes on big triangles. Does these triangles have visible edges?
Have you tried to reconstruct all the top part? Perhaps if you could build something like this it could help:
Hope this helps
Bernard Lebel
Hi Atyss,
Yes - I’d tried rebuilding the poly lines as you’d suggested, but all this did was alter the dark patches - shifting them - it didn’t actually remove them - it made it worse in many respects with the dark areas becoming even larger…
I have the feeling the models with this problem are doomed, but that’s ok - I’ll just have to be more careful in future to notice when it happens initially - it seems I spend too much time working in wireframe…
Thanks for your help,
skyPhyr.
Well seeing that your rendered image looks fine (does it?) I wouldn’t bother too much. Only if you have problems with shading and textures when rendering or artifacts that you should get dirty with this thing and find a solution.
Just my 2 cents
Bernard Lebel
Have you checked you light cone?
Maybe it is too small?
Markus
The rendered shadow isn’t supposed to be there. There are about 6 lights in the scene that all completely cover the whole mesh with the cone so the lighting in that spot is flat, but isn’t rendering correctly…
It’s really got me stumped..
Cheers,
skyPhyr.
I know this problem. The dark areas are artifacts of videocard.
I use GeForce II and I culdn’t solve this problem
