Daul G4 Macs?
Waht up with Dual G4 Macs? We have one at work and it is junk! Any other opinons?
“What” Sorry cannot spell.
apple trying to get rid of old motorola cpu’s from the eighties.
“I put my faith in the power of my own mind.”
ICQ#58898276
hehehehehe
works fine for me …although the os 9.0 seems to leak memory like a code based titanic!! geez, 8.5 was great what the hell happened ?
hmmm, I am just wondering why 9 of the 20 fastest supercomputers are using powerPC technology? Asci white, Asci Blue and some others…(http://www.top500.org/list/2000/11/) They must be silly using such oldfasioned technology.
“20 fastest supercomputers are using powerPC technology”
One question..
how well do these “supercomputers” you speak of run Softimage and Maya?
My phone is 2000mhz but its not very good at photoshop..
Come on now! the term “supercomputer” has been used so loosly in the past 10 years its more a marketing tool than anything else. and By the way
.“…9 out of 20..” is a failing mark in any test I have ever taken.
ICQ#58898276
lol
and speaking of supercomputers…there was a real cray supercomputer (4 years old or some such thing) for sale on ebay recently for 40 or 50 k us.
hell of a bargain if you were to cost it out on a per cpu cycle basis.
A cray? hehe cool put me down for 2 of them, my Speak 'n Spell is broken. Thats a bargin! I will have to put it in my guest house though
ICQ#58898276
I don’t care about the term “supercomputer”. As you said, I now it means not very much. I only tried to say that powerpc tech is used in nearly 50% of the top 500 list, and therefore it could not be as bad as you wrote. Heard some rumours that apple plans to switch to the power3 chip which is much more powerful than g4. I don’t think powerpc tech is at its end. Of course intel and amd did some great steps, but they can run into troubles very quick too.
tip: maybe you should increase ram in your phone to get better performance with photoshop.
Dont get me wrong, I use macs too and know of the tech you speak of. Most of the tech available to you and me is “old” an all platforms. The manufacturers are wizards at stretching technology till it has no more blood to bleed and that goes for IBM/Motorola, Intel, Amd and others. I personaly would like to get rid of windows and mac os and just use Linux redhat on a dual 933 , 1 gig of ram, all scsi 15,000 rpm hard drives and a clean 21inch flat crt monitor. I like the command prompt and the fact that redhat installs no extra fluffy interface crap and 1000 drivers for things i will never install, makes things run insanely fast . I may use os10 if it is flexible enough to survive in a dual or tripple boot situation.
ICQ#58898276
the whole dual g4 thing its a waste of money if you ask me cause os 9 isnt able to use both prossecors
dont try and fight this cause its true my friend at work loves macs and has some mac magazine mac addict or something like that and in it it has a layout about the dual g4 macs and it even says there that they show no real increase unless useing OSX
so until osx comes out your second prossesor in your dual G4 mac is just sitting there waisting space
guess what? Its not a waste of money for anyone but Apple becouse it costs the same anyway and doesn’t come with another configuration . Photoshop uses it haha
naw OSX will be out soon and is getting great reviews so far . I think Apple thought it’d be out sooner but they are waiting on their developers to get there products ready/ OSX is ready to go.
I don’t see any important difference between my dual NT (sgi320) and a dual G4. If the programm is not written to use both cpus, Windows NT does not help you anything. For example: maya(NT) does not run on both cpu’s (only the rendering part), after effects (NT) does only improve to 60%, so it uses 10 percent of the second cpu…
The question if dual or not is the same to both platforms: is your software written to use both cpu’s or not? Of course on the mac there are very few packages which are able to do so. If you do big photoshop work the dual g4 is really a big rocket and outperforms most Nt machines.
ps. some people say macos is not multitasking enabled: is not true. Or how would you explain the ability to render in cinema4d and aftereffects at the same time?
Agree that apple is using the dual thing mainly as a advertising help. As I wrote because of the lack of mp soft, it does not make much sense to use mp g4’s, but there is also the question about the chicken and the egg…
Doing something and doing something well are two different things in on themselves. The OS you use does make a difference in SMP. Even if your applications arnt multithreaded, its your os that will or will not give you the option to have a choice of what the two cpu’s can share .Its called “Processor Affinity”! Weather or not you can do this depends on your OS. If your OS was not written to use both cpus then your out of luck. The amount of cpu usage regarding applications is not just dependant on your application, your OS can be written do deal with threads better too. You may not be able to see the difference between your two systems but the difference is made in the proper configuration eg in your mac if you do not configure your memory for photoshop..hehehe if you know .. you know what im getting at..
ICQ#58898276
I benchmarked this “wonderful” G4 Dualy doing just a simple fill in Photoshop with a 30000X10000 box at 500 resolution and it crashed the first time, cause…the hard drive was bad, mind you this was 2 days after we bought it brand new. So after getting the new hard drive I tried it again and it took aprox 3 minutes,at home one of my computers is a P3 500mhz with same amount of ram, etc. and I ran the test on it and it took about the same, now if the dual G4 was so blazingly fast it would have bet it by more than half according to Apple. I am not impressed at all. I know there should be a difference. I have a friend who owns a system with a P3 Copper 733mhz that we overclocked to aprox. 1000mhz without changing voltage and it rips big time! It is,seems three times faster than my P3(alot has to do with the on-die cache the 733 has). As others have said the Apple is a waste of money, especialy without any software that anyone other than Bubba uses to make Christmas cards for his kin-folk with. Oh, and stability about as stable as a drunk one-legged horse(we have G3’s, G4’s, etc. and they are unstable)
I set it up all ways I could and every application I alloted heaps of memory too, so much that I cannot multi-task, for example I can only run flash and the finder(OS) or the wonderful Animation Master and OS 9. I never got out of memory warnings or crashes on my P3 even when I had one stick of 128mb’s. Also I dedicated 3.5 Gig’s as a scratch disk.
The perfect OS does not exist, not to me. (didn’t had my hands dirty on linux until now..) There are lot of features on all three OS’s (Irix, Nt & Mac) which I like and which I hate. I know it’s silly but if I could wish It would be a mix of different features from all three. For example: why can’t they mix the file browser systems from irix, nt and MacOS?
Osx is at least an interesting new perspective.
Photoshop’s FILL is a single thread, and not a very good test of a processor’s abilities. Try running through a batch of filters… you don’t have to use a res so high.
I have an O2 10k, a dual PIII-600 (2000), and an iBook on my desk at work, plus I manage three servers - one Linux, one 2000, one NT4. Each has their goods and bads. I will say that OSX on the iBook hasn’t crashed on me once, which is a better record than any of the other systems.
Benchmarking an dual Apple without using OS X is pointless. When I get my beta of Maya OSX, then I will be doing a lot of testing to see if our house might consider migrating to that platform. Most of our rendering is not handled by workstations. I want stability without SGI’s ridiculous prices. OSX blows the crap out of Gnome or KDE, interface wise.
I have heard OS X is UNIX with graphic interface and easy feel of Mac OS. It is supposely rock solid and since SGI is doing crappy they probably will flop and team up with Mac or something which would drive Alias towards Mac more…either way I don’t care so long as I can use my sytem for a whole day without one crash(dreaming, la, la , la). And not having to wait 16 hours for a frame. I do somewhat realize that was not a true test, but what can I test with? No software yet, though Maya OS-X I want to know the true figures on what the Mac is capable of. Though Apple claims the 400MHZ G4 is faster than/as fast as a P3 800MHZ Coppy…all I am saying is one 450MHZ is barely faster than(if it is at all) my 500MHZ half-speed, 512k cache dino, and the G4’s have a 1mb each. Hummmmmmm?! Maya will prove the better.
Nothing against Mac, probably just cause I work with them all day and they are always crashin and not capable of doing things that I bring home to my PC and it chews right through. Just currently I wouldn’t invest a cent in one, until they change and stick with it.
Also I haven’t really noticed a diffrence in speed on the filters either, I tried.
I run Win2K at home and used at school with Maya 3.0 and love it!!! Crashed once, after trying for a while to crash it with every other task(s), finaly did while I was rendering a 1,000,000 face scence that had five lights and lots of textures and mapping and I went into to task manager and changed Max’s Memory Priority from Normal to Realtime while it was rendering. That did it.
