I have resigned myself to the fact that i cannot attach the individual control points from a rotoshape to trackers and have the roto deform to match the track points.
Is there another way to achieve the same result, without having to manually keyframe every point on every frame?
I am trying to mask roof shapes on a 3d model shot. Keying is not possible because the whole thing has been painted in pastel colours (even the sky tends to blend in). I have been able to get good tracks on most of the roof points, but cannot think how to use these as the shapes deform over time becuase the shot is a flying zoom in, so the geometry is constantly changing.
What version of Shake are you running? You can attatch trackers to control points in 4. Or in 3 you could average your tracks to create a centre one and attatch a tracker to that. You would still have to keyframe but it would get you partly there.
Good Luck!
QUOTE(soupkitch @ 09/27/05, 01:15 AM)
Good Luck!
[snapback]215680[/snapback]
using 4. I had tried attaching a tracker to each corner position and the relevant roto point to that, and it did move to some degree, but as it was nothing like the trackers own movement, it just caused me more confusion and i could not figure out what the reasoning was behind the programming?
Is it just me, or would i be a really useful feature to be able to track the individual roto control points?
You should double-check that...
Are you sure you're attaching a relevant tracker to each of your rotoshape points? It should work if you do it this way.
QUOTE(bluepixel @ 09/27/05, 11:22 PM)
[snapback]215817[/snapback]
well i tracked a point, made sure the track was a good one by examining every frame. I then create the roto using straight lines (no bezier curves) and made sure the roto points were in the correct position and that the point number matched the tracker number. Then attached each point to its corresponding tracker.
When the seq is run, the roto shape moves off toward the edge of frame, completely different to the motion and deformation of roto's geometry that i needed.
Is that the correct way?
