Hi, I’m using Maya 3.5 on mac os X and encountered a pb about deleting by type… After modelling a object for a while and being sure of it, I want to delete the history (inputs) but I would like to be able to do it without deleting the node “makeNurbsshape” in order to still be able to eventually change something about it…
And then, comes the question, abit more general… : Can we delete history nodes one by one ?..
I’ve always felt uncomfortable with the term “delete” history that Maya uses. I think it should be refered to as “bake” history, or something similar. If you “delete” something from history, its as if it never existed, removing it’s mark from the object. “Baking” history removes the history, but leaves a mark. Yes, to answer your question, you can individually “delete” nodes in history, but again, it sounds more like you want to “bake” individual nodes in history. To “delete”, select the object, open the Attribute editor, go to the tab of the node you want to delete, bonk the “select” button in the Attribute Editor, rmb in a camera view to make it active, and “delete”. However, there is no easy way (there’s usually always some way…) to “bake” selective history, or “bake” all history except the “makeNurbsShape” node. If you think about it, it makes logical sense that it wouldn’t work. You make a nurbs sphere, then you trim it in half. The “makeSphere” node is in history, and so is the “trim” node. If you could “bake” the trim node, the data flow would go “make nurbs sphere” → “old baked trim data that dosen’t exist” → ouput shape. If you’ve removed that “old baked data”, Maya wouldn’t know how to trim it! Furthermore, if it “somehow” could figure it out, if you changed the creation parameters of your spehre, parameters on which the trim was basing it’s math, the trim would suddenly wig out. I’d try to find some other way to solve your problem, whatever it is
The construction history of an object is contained within the “make” node that you see - that’s why it goes away when you delete history.
If you select your object and view it in the hypergraph, then click on the icon that looks like a Starship Enterprise on the icon bar (show up and downstream connections) you’ll see the history nodes and all the connections. Some you can delete one by one, others you can’t. You can’t go back in time and delete your grandmother and expect to have been born - it’s the same thing.
As for the “bake” history idea, well, that’s just semantics. If you create a sphere, then go into the make node and change stuff around and delete history, you’re really just baking it in anyway.
There will be times that keeping history around will be desirable, and others when it’s downright inconvenient. Your choice.
